Screen Protector
Discussion in 'PS Vita Forum' started by neilo, Sep 9, 2005.
Tags:
  1. neilo
    neilo
    Apr 18, 2002
    1,564
    38
    +21
    Whats the best one out there ? Any views
  2. Cowden_harley
    Cowden_harley
    Jun 6, 2005
    4,646
    FIFE, SCOTLAND
    +217
    one made by a comapny called HORI. You'll get them on ebay for £5 delivered. If you look on gamespot.com they done a feature on the screen protectors. Its what I use it minimises glare and you dont notice its on.
  3. neilo
    neilo
    Apr 18, 2002
    1,564
    38
    +21
  4. Spacecat
    Spacecat
    Apr 1, 2001
    2,863
    London
    +557
    i bought the game kit and just used the screen protector.
    if i say so myself i done a fantastic job (or more likely the screen protector is very good) but you cannot tell that there is anything covering the screen. no bubbles no dust NOTHING!
    I was well pleased how it came out
  5. atariboy
    atariboy
    Mar 31, 2005
    259
    Swindon
    +6
    I had a jap psp, a us psp and now a uk psp and have tried several and found Madcatz to be the best. But being a static screen protector, you need to either fit it very quickly to avoid dust or fit it in an air conditioned room. They cost £7.99 from most outlets of Dixons, Curry's and PC World but would probably be cheaper on Ebay.
