Screen Protector for D90
sep8001
I have seen the GGS v3 and the v2 the difference between the two being on v3 the rear screen protector is like the nikon one and not a stick on one.
Has anyone tried both? If they have which one did you prefer v3 or v2?
Thank you.
Strobe
Thank you.
I had the GGS stick on glass ones for both the D90 and D300s. They do the job well and are recommended. The only issue with the removable types (such as the OEM Nikon one) is that if you get a bit of grit stuck between the protector and the screen in can still scratch.
