Screen performance?
Discussion in 'Projectors, Screens & Video Processors' started by rigman, Jul 15, 2002.
Thread Status:
Not open for further replies.
  1. rigman
    rigman
    Dec 14, 2000
    2,970
    83
    East Yorkshire
    +115
    If you change your screen for a better quality one do you automatically get a better picture or does the projector have to be re-tweeked?
    Obviously the screen would have to be the same size and sit in the same place as the old one. Projector is Barcographics 808s with 300 hours on the tubes.
    cheers
    Darren
  2. Matinee
    Matinee
    Jan 25, 2002
    225
    16
    bolton
    That depends on the screen. If the gain on your new screen differs from the old, you'll need to adjust contrast and brightness. If one of the colours has been pushed up a tad to cope with the old screen it may need moving down again etc.
    So, yes, you're basically looking at some tweaking.
    PK
  3. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Define better screen. Higher gain or tab tensioned?
    Even changing from a white wall to a Stewart studio tech from the projector point of view I would be very surprised if you would need to adjust any thing other than mechanical focus.
    Very few screens have a colour cast.
  4. rigman
    rigman
    Dec 14, 2000
    2,970
    83
    East Yorkshire
    +115
    At the moment I have a Dalite Cosmopolitan Electrol with video spectra coating which is 1.5 gain.
    I am thinking of changing it for a fixed screen sometime in the near future with Stewart Studiotek material. I think the gain is 1.3.
    thanks
    Darren
  5. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Side by side they are very close.
  6. rigman
    rigman
    Dec 14, 2000
    2,970
    83
    East Yorkshire
    +115
    Roland,
    are you saying then that the difference would not be worth the extra money?
    on a separate issue, did you get my email regarding the re-installation of my Barco in my new house?
    thanks
    Darren
Thread Status:
