Screen Modification Tips
Discussion in 'Projectors, Screens & Video Processors' started by henry1234, Feb 28, 2003.
Thread Status:
Not open for further replies.
  1. henry1234
    henry1234
    Nov 15, 2002
    341
    Worcestershire
    +8
    First of I have an 8ft Owl electric screen, gain 1.2, vinyl material, hung by a heavy metal bar on the base.
    I am only projecting a 61inch wide image. The screen is 92inch wide.
    I currently have one screen edge butted up against the image but only on one side, leaving 31inch gap of white vinyl on the other, I hang a black cloth on this side but I do not get the sharp black edge from this method.
    Due to the nature of the metal rod design there is very slight curl at the edges.
    Instead of swapping to a smaller screen which would have slight curl at each end I have been thinking about using the centre flatest part of the screen and then blanking the left and right.
    I would like to make some sort of blanking that produced sharp black edges left and right. Has anyone done this and what products are used?
    Could I paint the screen black at the left and right edges?
    Would the method of using only the centre of an oversized screen be a better alternative to a very expensive screen that has gone to great lenghts to flatten the edges?
  2. henry1234
    henry1234
    Nov 15, 2002
    341
    Worcestershire
    +8
Thread Status:
