screen mode changing - grrrr
Discussion in 'General TV Discussions Forum' started by Ashy, Feb 12, 2003.
  1. Ashy
    Ashy
    Jan 3, 2003
    377
    +14
    is there any way to stop my FQ75 from changing its screen size when switching to the AV channel I have my DVD on (AV3)
    whenever i go to that av channel it just seems to randomly switch, its now started when watching some SVCD and VCDs as well, even if i switch it back it changes again after about 5 mins.
    the dvd player is a DAV550
  2. Ashy
    Ashy
    Jan 3, 2003
    377
    +14
    anyone?? :rolleyes:
  3. Ashy
    Ashy
    Jan 3, 2003
    377
    +14
    Surely someone could at least suggest something here please :)
    Basically, I have a DAV550 linked to a FQ75 using a QED svhs to scart lead.
    When watching either VCD or SVCD the screen auto switches after 5 mins or so to 14:9 size cutting the top off the picture. Obviously this is immensely annoying and I would like to somehow stop it from happening if possible as it seems rather stupid.
    Is there any way I can set the TV so that it will never change screen format? Is it something to do with the DVD player at all?
    I had to have the DVD players firmware upgraded to fix the subtitle bug.
    Someone please help! :)
  4. nathan_silly
    nathan_silly
    Try using composite, although using S-Video tp SCART perhaps somethine wrong with the SCART lead (12V signal wire)
    Have you got any DVD's?
  5. Ashy
    Ashy
    Jan 3, 2003
    377
    +14
    duh, i feel rather stupid now, went into the menu on the TV and it has auto format set to full on AV3 (the DVD one...)
    I didnt know about that bit, only the normal auto format setting which was off :blush:
