screen masking border
Discussion in 'Projectors, Screens & Video Processors' started by squid, Feb 20, 2002.
  1. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
    i have a 4:3 screen 77" wide sceen (da-lite model B). i was thinking of getting one a bit smaller . not so much for myself but for the wife who thinks it a little big for the room
    i was thinking rather than buying a new one i could make the masking on the screen i have a bit thicker . any idears ?
    if it was a fixed screen there would not be a problem i would use some black velvet .but the screen is a pull down with a tv behind so needs to be up when watching normal tv
    i just thought i would just ask if anyone has done this and what the used :)
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    How about a black roller blind with whole cut out you could then pull that down in front of the screen for the smaller image.
  3. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
    could be an idear . if i could get my hands on a black blind . i wanted one for the window behind the screen but aftyer a lot of window shopping i had to go with a forest green one as i just could not get black .
    i have seen small ones around but not in the sort of size i would need unless i had one made (i could get a new screen cheeper)
    is there any sort of paint i could use ? what do the screen manufacturers use to make the boarders ??
    if i did do somthing like stick velvet on the screen would this work or not :confused:
  4. Winnie
    Winnie
    Mar 12, 2001
    219
    Enfield
    +4
    I've been looking into this myself. I am looking to purchase a Da-Lite Model B screen (widescreen), but can't work out why the widescreen version (45x80) is more expensive than the normal 4:3 version (60x80). ??
    The difference in price is £212.80 (widescreen) to £176.70 (4:3). Since I would also need to add the cost of a 12" drop to the w/s version, bring it to £242.80 I have decided to purchase the 4:3 version and use a black fabric spray to turn it into the widescreen version with 12" extra drop I require !!
    Fabric spray paint can be purchased from most hobby/craft stores asnd I think some larger DIY stores (B&Q).
    Reckon I should save myself £65 less cost of paint & masking tape.:D
    Winnie
  5. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
    are you sure these fabric paints would be ok on a screen . the material it is maid of is more of between a ruber and a paper .
    i would worry about anything in the paint that could break down the surface :confused:
    i would like to hear from somone who knows for sure befor i would go ahead. it could blister the screen and not take
    what sort of paint is used by the manufacturers and where can you get your hands on it . i would rather have that . the other thing is can you actualy get matt black fabric paint
