Screen ideas required
C
conorandlucy
We have just moved to a new house and our main living room is 14'6" by 22' something. The projector will be mounted on one long side of the room and a screen on the other side.
We bought an InFocus IN72 projector. We need a screen that is best suited to this machine and want to know what would be the best screen for the job :lease:?
Thanks.
rich2000
Need more information.
If it is for a room where you can control light then a standard matt white 1.1 gain screen will be most suitable.
With regards the size that is pretty dependant on where you put your screen, although i would guess something about 2.0m to be best!
Rich
HCSV LTD
