Screen grabs in PowerDVD
Discussion in 'Desktop & Laptop Computers Forum' started by Bada Bing, Jul 25, 2002.
  1. Bada Bing
    Bada Bing
    Aug 8, 2001
    530
    Scotland
    +5
    Whenever I hit printscreen or use PSP capture, all I get is a black screen. How to I take snapshots from DVD's then?
  2. timothyw
    timothyw
    May 14, 2002
    521
    London W2
    +29
    You need to use the built in powerdvd capture. Theres a camera like button on the control bar, hit that while you have it paused. Or you can simply press c. This will capture the frame to the clipboard, you just need to paste that into PSP. Or you can set it up to capture to file, or desktop in the configuration.
  3. Dumfy
    Dumfy
    Sep 25, 2001
    146
    Cardiff, UK
    I had a similar problem with capturing. After digging around I found that "hardware" acceleration needs to be turned off otherwise the capture won't work. Turned this off and I now have a nice selection in the capture folder.
    Hope this helps
    Dumfy
  4. timothyw
    timothyw
    May 14, 2002
    521
    London W2
    +29
    Well mine works fine with hardware acceleration turned on... I guess it depends on the hardware. Its probably a good idea to turn it off just in case (or indeed if you have problems).
  5. Bada Bing
    Bada Bing
    Aug 8, 2001
    530
    Scotland
    +5
    Thanks guys, I'll give it a go over the weekend... :)
  6. Bada Bing
    Bada Bing
    Aug 8, 2001
    530
    Scotland
    +5
    What version are you guys running? I'm running 4.0 and there's no camera icon. :(
    I tried turning hardware acceleration off in display properties, but it never worked either...
  7. timothyw
    timothyw
    May 14, 2002
    521
    London W2
    +29
    Hmm i'm running 3 but i wouldn't have thought they'd remove the functionality. It might be the skin you are running powerdvd in. Check in the power dvd options that there is actually a capture tab; If there isn't they might have got rid of the screen capture. If there is, try a different skin- i'm using 'Oscar' and the camera button is just to the right of the progress bar, at the bottom.
  8. Bada Bing
    Bada Bing
    Aug 8, 2001
    530
    Scotland
    +5
  9. timothyw
    timothyw
    May 14, 2002
    521
    London W2
    +29
    I can't argue with that, there is no icon. Find attached what mine looks like. I would again suggest you check within the powerdvd configuration just to see if there is a capture tab, if not we can only assume your version doesn't support it. It may be possible to get another program that will do the capture for you, but i don't know of one to suggest.
  10. Bada Bing
    Bada Bing
    Aug 8, 2001
    530
    Scotland
    +5
    Thanks mate, at least I know I'm not going blind! :D
    I'll try and get hold of another version...
