Quantcast
Screen for ht300 xtra
R
RAM69
I am in the process of purchasing a Sim2 HT300 XTRA and was wondering what sort of screen you recommend.
I would like a 120 inch diagonal 16:9 screen. I want a fixed screen as this will be going into a dedicated room. The projector will be mounted on the wall opposite about 6m from the screen.
Any suggestions of makes and costs.
RTFM
RAM69,
I would advise you to talk to your dealer who is supplying the Xtra
If he is an approved Sim2 Dealer he should have the knowledge and experience to help you choose and supply the best screen for the job.
R
RAM69
Thanks Jeff.
I just like to have as much knowledge as possible before I talk to the dealer so I can understand exactly what he is telling me.
