W
windowlicker
Hello. I am looking for some assistance on a screen for this projector. I am mainly looking for something that is pull down and will not wrinkle. The native rez is 4:3 but it will also do 16:9 and 5:4. The projector will be around 16 feet from the wall on a shelf. This is not a basement room so there will be some external light during the day. I am limited on the brands I can purchase however. I place the order through my work vendor witch happens to be CDW.COM. They have these brands
Dalite
Bretford
Mitsubishi Digital Electronics
Draper
Quartet
Epson
InFocus
Chief Manufacturing
NEC Visual Systems
Proxima
Plus Corporation
SERIOUS MAGIC
I was also torn as if I should go with a High contrast grey or high power screen. Da-lite also has something called Video Spectra 1.5 that is 35 degree viewing angle with a gain of 1.5.
Thanks for any help you can give. Here are the specs of this Optoma.
Resolution: Native XGA (1,024 x 768), SXGA+ (1,400 x 1,050) compressed
Brightness (typical): 2,300 lumens
Contrast Ratio
(full on/full off): 2000:1
Weight: 5.3 pounds
Dimensions
(W x H x D): 10.4 x 4.11 x 9.3 inches
(265 x 104.6 x 236.4mm)
Noise Level (typical): 32/27dB (ECO)
Lamp Type and Life: 200-watt SHP lamp
5,000 hour
Aspect Ratio: 4:3 native, 5:4 and 16:9 compatible
Input Connections: PC/Video:
15 pin D-sub input (RGBHV/YPbPr input), DVI-HDCP
Video:
One mini DIN for S-video connector
One composite RCA type connector
USB Mouse control
One Audio input for every input- (3.5mm Mini Jacks stereo)
Output Connections: 15pin monitor output (passive)
Computer Compatibility: IBM PC and compatibles, Apple Macintosh, iMac, NEC PC98 series, Fujitsu FM Towns, and VESA standards SXGA, XGA, SVGA, and VGA (resizing)
Video Compatibility: NTSC/PAL/SECAM
SDTV (480i), EDTV (480p), HDTV (720p, 1080i)
Throw Ratio: 2.0 - 2.4:1 distance/width
Keystone Correction: ± 16 degrees
Remote Control: Wireless remote
Projection Screen Size (diagonal): 24.6 to 246 inches (8.58 to 0.84 meter)
Projection Distance: 3.9 feet to 32.8 feet (0.6 to 6.24 meter)
Projection Lens: F= 2.4~2.65, f=28.04~35.59mm, 1:1.2 Manual Zoom and Focus
Projection Methods: Front, rear, ceiling, rear ceiling
Data Loop Through: Passive monitor loop through
Horizontal Scan Rate: 15 to 100 kHz
Vertical Scan Rate: 43 to 120 Hz
Operating Temperature: 41-95°F (5-35°C)
Power Supply: AC Input 100 ~ 240V, auto-switching power supply
Power Consumption: 265 watts (maximum)
<15 watts (standby mode)
Security: One Kensington key lock port
Tilt Angle: 7 degrees with elevator mechanism
IR Receivers: Front and back
Uniformity: 85%
Displayable Colors: 16.7 million colors
Standard Accessories: AC power cord, VGA to VGA, Composite Video
Optional Accessories: Short Throw Lens
Ceiling Mount Kit
15-pin to 3 RCA component/ HDTV adapter / SCART adapter
Warranty: Two year limited parts and labor, 90-days on lamps
Dalite
Bretford
Draper
Quartet
Epson
InFocus
Chief Manufacturing
NEC Visual Systems
Proxima
Plus Corporation
SERIOUS MAGIC
Contrast Ratio
Weight: 5.3 pounds
Dimensions
5,000 hour
Video:
USB Mouse control
Uniformity: 85%
Ceiling Mount Kit
