Screen Drop, how big?
Discussion in 'Projectors, Screens & Video Processors' started by sirp, Jul 16, 2003.
  1. sirp
    sirp
    Jan 20, 2002
    887
    28
    Derby
    +53
    how far can the electronic screens drop, im trying to work out its hanging position, seeing how low i can go
    cheers
  2. Kramer
    Kramer
    Depends on the size, type (16/9 or 4/3 etc..) & manufacturer.
    Suggest you look at individual screen sites - usually .pdfs available with all the necessary info.
  3. sirp
    sirp
    Jan 20, 2002
    887
    28
    Derby
    +53
    ok, will do, will be 5ft scrren 16:9 though i think
  4. Jonny1973
    Jonny1973
    Is your projector desk or ceiling mounted???
    If it's ceiling mounted, the lower you have the screen the lower the projector will have to be. Mind your head.
  5. Burnsip
    Burnsip
    I mounted my projector to the ceiling, and I have a ceiling mounted screen. The projector hits the screen perfectly without any keystone adjustments, and my projector is only a couple of inches lower than the ceiling. The screen is 52" in height. I wouldn't worry about having the projector hanging down too low from the ceiling. The ceiling bracket can also swivel if you need it to, but you will need to make a minor adjustment to your keystones.
  6. sirp
    sirp
    Jan 20, 2002
    887
    28
    Derby
    +53
    i want it wall or ceiling mounted, my ceiling is quite high..just concerned about my seating position, dont want to be looking up too much, as my room is 3.4m wide!
