Screen cleaning
Discussion in 'Projectors, Screens & Video Processors' started by Mr Bump, Mar 28, 2005.
  1. Mr Bump
    Mr Bump
    Jun 3, 2003
    365
    Leicestershire
    +3
    Hi, I have a new Draper Onyx screen and I just wondered about cleaning it. I managed to get a couple of hand marks on it during assembly and wasn't sure about using any type of cleaner on it, or if I should just use a soft cloth. It is a tensioned vinyl screen.
  2. Otto
    Otto
    Jun 19, 2003
    322
    28
    +61
    Normally, any screen fabric can be cleaned with some water and a cloth. Assuming the handmarks are caused by dirt, this should do.
    Alternatively, you can use a mild soap solution.
    Make sure you don't use any more "aggressive" cleaning solutions, as these might damage your screen.
    Best regards,
    Otto
  3. Mr Bump
    Mr Bump
    Jun 3, 2003
    365
    Leicestershire
    +3
    Lovely, thanks! :)
    I just got a very similar response from Draper themselves:
    Care and Maintenance: Clean surface with a solution of mild dishwashing liquid diluted with warm water. ARMOR ALL® Multi- Purpose Cleaner may also be used. Remove stubborn stains with a solution of rubbing alcohol and water. Do not allow any cleaners to be absorbed by the fabric. Do not use cleaners which contain abrasives or wax.
