Screen calibration
explorer
Hi all,
I have just fininshed the calibration of my Pioneer 435 fde, she has had a break in period of about 3 weeks and I used theTHX set up I found in 'Finding Nemo', I managed to do the all the set up except the tint adjustment as this method requires the use of blue tint glasses they never came with the dvd as it was a rental unit,(I am not sure that you would get them if you had bought the dvd either)!
The results are very good and the skin tones look more life like and colours true to life!
Here are my settings after calibration.
Av selection-Standard
contrast 43
brightness Plus 1
colour minus 19
Tint 0
sharpness plus 1
Pro adjust settings menu
Pure cinema Adv
colour temp Mid
Mpeg nr low
Dnr Low
Cti on
Dre mid
colour managment default settings.
I dont know if it could be better using DVe disk?
Please if you are about to do this make sure that you have decent cables to connect and try not to let video cables regardles of type cross over power cables, this can cause mayhem and I know this for real as I play the Roland tD8 drum kit into Mackie srm 450 speakers, Power lines crossing signal feeds induce hum and buzz, it has to introduce crap to video signal too- Dont do it please, use shielded cables were you can afford to please! :hiya:
Rocky 4K, Creed 3 and boxing movies, Shazam 2, 65 trumping Jurassic World Dominion, + Picard & Mando
