Screen burn
Discussion in 'Plasma TVs' started by areuwithmee, Aug 22, 2005.
  1. areuwithmee
    areuwithmee
    Hi Guys
    I got a friend who has the 42" lg PX3 model but he has got screen burn with one of the digital channels. He's tried the screen wash facility but the logo is still visible. Is there anything he should be doing such as turning the brightness and contrast HIGHER to possibly wash away the logo or is this permanent now?
    Thanks chaps
  2. k0rn
    k0rn
    Best way to get rid of it (if it´s a short burn) is to enable the "White noise" and let it run for some time... (white noise is when there´s no signal available)
  3. areuwithmee
    areuwithmee
    Thanks 4 reply k0rn.
    Is that the white wash facility your talking about mate, if so how long should it be on for?
  4. johndon
    johndon
    Feb 3, 2002
    1,928
    48
    +89
    Depends how long it takes to get rid of the burnt in image...
    It's worth nothing that watching a channel with no static images or logos should be just as effective.
    John
  5. areuwithmee
    areuwithmee
    Should he now UP the contrast and brightness to wash away the logo?
  6. johndon
    johndon
    Feb 3, 2002
    1,928
    48
    +89
    Well, it's generally recommended that you turn the contrast down to avoid screen burn.
    The burnt image will, hopefully, fade away gradually but it's not likely to be a quick process assuming that it works at all...
    John
