Screen Burn
Discussion in 'Plasma TVs Forum' started by billgreenwood, Jan 3, 2005.
  1. billgreenwood
    billgreenwood
    I'm planning on purchasing an Lg Mz42pz45v and am a littte concerned that plasmas are rumoured to suffer from screen burn.
    Is this just a myth?
    I've read some conficting stuff on the net about this. Some people say that you should "run-in" the screen continuasly with a screensaver for the first 50-100 hours.
    Is there any truth that the broadcaster logo on the corner of the screen or the newsbars at the bottom will eventually become a permanent ghost on the screen. I've read that with even 20 mins viewing these can be a problem.
    Can anyone clear up this subject?
    Thanks in advance.
    Bill
  2. johndon
    johndon
    Feb 3, 2002
    1,971
    63
    +108
    Plasmas can suffer from screen burn but you need to leave a static image on screen for hours at a time for this to happen. You can get image retention from logos but this will go away once the logo is no longer displayed.
    It's often advised that you reduce the contrast on the screen for the first 100 hours or so althouth you'll probably do this anyway as it's usually far to high out of the box.
    I watch all my TV through Sky so plenty of logos and have used a PS2, XBOX and PC for 3-4 hours at a time and have had no problems with permanent burn.
    HTH
    John
  3. billgreenwood
    billgreenwood
    This is good news, I was thinking that I would have to be putting up with a cartoon network logo whilst i was trying to watch the footie!!
    Thanks for the reply
