greyhound74
Does anyboby have any screen burn issues playing the 360 through the PX60?
Greyhound
Greyhound
yes, I think more developers should use the fade out system. the health bars should be a thing of the past now, with COD and GOW showing how it should be done now.watch out for marathon sesions on dead rising though, the health bar soon burnswish it would fade out like gears of war does
If i play for a hour+ and reboot (look on the initial white boot up screen and can you see a slight circle (from the compass)?I've played my 360 for around 5 hours in one evening session ... playing COD3 ... and not one issue with Screen Burn.
Ben
Why is it so bad to use dynamic? Just bought my PX60 a week ago and have been using cinema mode. I've tried using Normal also, fiddling with the picture settings but I cant get either mode to look anywhere near as good as dynamic. They just look dull and washed out. Is it ok to use dynamic after the 200 hour run-in?mines ok.. has some retention, just don't use dynamic.
Saint row was the worst,, played for 3 hours on dynamic by mistake.. took 1 hours to get rid of the retention.. ouch.. (slight panic at the time).
And i totally agree, transparent (configurable) or fade in huds should be the normal now
Dynamic is basically all of the settings on max and then some. If you think you getting a decent picture with 100% contrast and 100% brightness "you should have gone to specsavers "Why is it so bad to use dynamic? Just bought my PX60 a week ago and have been using cinema mode. I've tried using Normal also, fiddling with the picture settings but I cant get either mode to look anywhere near as good as dynamic. They just look dull and washed out. Is it ok to use dynamic after the 200 hour run-in?
I have been using my 360 since I got my PX60 - never a problem. Just some retention which fades after 10 to 15mins. This is only even viewable in pitch dark room on a black screen. Use it! Retention is by nature of plasma technology. Only if you leave the same image for hours will it burn. eg avoid playing the same game for over 2hrs for the first 100 hours of use. Simple as that.eob, to be on the safe side (and if you can bear it!) I really wouldn't use the Xbox 360 at all on your PX60 during the 200 hour run in period.
I was gonna suggest this aswell.eob, to be on the safe side (and if you can bear it!) I really wouldn't use the Xbox 360 at all on your PX60 during the 200 hour run in period.
I have used Dynamic but I reduced the contrast/brightness and colour bars to around 50/60%. This gave me a much better picture than Cinema/Normal modes which with a lot of tweaking still look a little dull. RE:The Video Essentials DVD, Im no AV expert and tried using the THX optimiser On the Star Wars DVD. I couldnt make head nor tail of it to be honest!Dynamic is basically all of the settings on max and then some. If you think you getting a decent picture with 100% contrast and 100% brightness "you should have gone to specsavers "![]()
I'd recommend buying something like the Video Essentials DVD which would be a good starting point in getting some acceptable settings.
BTW - By using DYnamic you are effectively putting the TV is super charge mode and will probably shorten it's life span.
