Screen burn on my 436 XDE
RedIndian
SKY SPORTS HD logo has been burnt in to my screen :( I have tried the trick of leaving the fuzzy screen on all night, but this hasn't helped.
Any ideas? help will be much appreciated :lease:
H
HunterUK
You've done the best thing already by letting the white noise display for a long period. It may take a couple of goes to get rid of it completely though. You may find its just a case of screen retensino, rather than screen burn. If that is the case, then it should slowly fade away.
RedIndian
Here's hoping. Will try it another few times.
It wont help. I had 4 of these screens before I got a refund and bought a pansonic.
When mine did finally go...on a white screen you could see nearly all the logos from sky, the world cup scores and more! It was like an etch a sketch!
Best thing I ever did...was get rid of that screen
Dan.Scott1234
*touch wood* my 436XDE has never had these issues thus far and it's got a few thousand hours on it. What brightness/contrast levels are you using and how many hours has your set been run-in?
The screen burn is a bit of a notorious issue on the 436 and other plasmas of the same generation, but it only seems to affect certain models... why can't there be a company who makes the perfect plasma!!
There is ... they are called 'Panasonic' or if your rich the 'fujitsu 58 series!'
Dan.Scott1234
Panasonic has had some problems also, I remember a generation of their plasmas that had a line running though them down the middle if I remember correctly. I do seem to hear a lot of good things about the Fujitsu though!
bodas73
Mine has been running for around 2500 hours and is fine, I do get some retention at times but it fades within 30 mins, I keep my contrast at around 20 on user setting for watching sky but for movies I have it set at 35 and it is great, my set was an ex demonsrator from Sevenoaks Sound and Vision and did have some retention on it so they did not run it in properly, it had around 1800 hours on it when i got it and i kept all the settings in the minus until it hit 2300 hours just to be safe a couple of nights on a snow screen and everything now looks fine so there is hope as long as you have the patience. Also when watching sports like the footie I will use zoom and it removes the logos from the screen. Good luck
I have the RXE and its been nothing but a pain since day one, i have it on very low settings but constantly get retention, some of which takes months to leave, my latest is retention from gears of war and has been on the set for over two weeks, its a real pain cos it means u cant play the games u want while the tv recovers , if it ever does.
scottyule
I get image retention issues when watching football on sky sports (score box in top left corner) but this usually disappears fairly quickly.
The main issue I have is when you change channels on sky and get their 'information' box displayed.
I have tried to minimise this by pressing the 'back up' button as quickly as possible when I change channels.
I still notice it when there is a very light (or white) background on whatever i'm watching.
Starting to get a bit bloody annoying now to be honest....!!
Have had the panel about 9 months now.
How did u manage to get a refund as the retailer i purchased from would not entertain it, they claim any image retention is my fault.
I got a refund (offer of a final swap) because pioneer agreed on the basis I had 4 dead pixels in a small area. My retailer stocked both so it made no difference to him.
Seriously. I went out to a customer recently with a 5 day old 427 and it had screen burn already! (plus the picture has a grain/dirty look to it)
mjcairney
Has anyone with screenburn/image retention tried this? I haven't (as fortunately my PDP435FDE doesn't suffer from either), but they seem pretty sure of themselves.
Cheers,
Martin.
scottyule
Cheers,
Martin.
It seems pretty similar to a dowload that someone was advertising a while ago on a different thread. You could download the item onto a dvd and it played a recurring white and black alternating screen which was meant to 'wash away' image retention.
I would assume that this disk is very similar.
I have just done about 2 hours of black and white fuzz on my panel and whilst the image has not disappeared completely, I can already see the image has faded SIGNIFICANTLY.
Give that a go a few times first and see how you get on.
I HATE SKY FOR HAVING THEIR POXY HEADINGS ON EVERY CHANNEL...!!!
Scott
Jaspington
You do know that you can set the timeout on the info box to zero seconds on the Sky set-up menu? It doens still pop-up v briefly, but might help
