Screen Advice Please
Discussion in 'Projectors, Screens & Video Processors' started by chrislewis, Mar 9, 2005.
  1. chrislewis
    chrislewis
    Jan 13, 2005
    2,481
    wolverhampton
    +25
    Hi all bit of advice please as there seems to be very little in the way of reviews on pj screens just treated myself to a infocus 7205 and want a nice manual screen to show it of to its best potential ive currently got a 69" draper luma ,im looking to go a bit bigger but not much as i sit about 11ft away from the screen budget wise around the £500 mark but less if poss.
    chris
  2. Member 14847
    Member 14847
    Aug 16, 2002
    491
    28
    +54
    Could I suggest you look at one of the Harkness mid contrast screens. The 7205 if easily bright enough for this type of screen and you'll get a noticable boost in contrast ratio. I use one at home with a ProjectionDesign Action Model One and the picture is stunning.
  3. chrislewis
    chrislewis
    Jan 13, 2005
    2,481
    wolverhampton
    +25
    thanks do you know to any suppliers of these
    cheers
    chris
  4. jkirkebo
    jkirkebo
    THX recommended screen size for 11' distance would be about 98" so I would settle for something around that since you shouldn't have much screen door problems with a 720p projector.
    The 7205 is quite bright, so I would either go for a 0.8 gain grey screen or use a ND filter unless you like insanely bright images :)
  5. hebawom
    hebawom
    Apr 16, 2004
    187
    19
    Matlock
    What is this THX recommended distance thing? Where could I find this data?
