mystex
I bought an 8 foot electric projection screen a couple of years ago which was great but over the months it has developed waves across the screen which really affect panning scenes. I contacted the supplier and they said it was now out of warrenty
I'm now looking at replacing the screen, and have thought about a tab tensioned screen rather than a conventional one because of what happened to my old screen. I have 4 questions:
1. Should these screens have a flatter surface, and will it deteriate over time?
2. Was I just unlucky or is this a common problem?
3. Do you think a tab tensioned screen is worth the extra(double) money?
4. Also, I have a NEC HT1000 DLP projector, bearing in mind I suffer from rainbows at times, should I go for less or more gain(if this makes any difference at all?)
Steve
Steve
