Screen advice needed
Discussion in 'Projectors, Screens & Video Processors' started by stevos, Jan 3, 2007.
  1. stevos
    stevos
    May 16, 2004
    6,179
    +580
    I have a sharp z9000 and always watch in pretty much pitch black.
    I don't have huge amount of money available so cheap would be good.
    Also i am not too sure how solid the wall is and so light weight or easy ceiling mount would be good.
    Which screen would you recommend?
  2. stevos
    stevos
    May 16, 2004
    6,179
    +580
    oh the image is approx 67inch (170cm) across or 79inch (200cm) diagonal
  3. AV Nik
    AV Nik
    Jul 11, 2006
    581
    46
    +100
    Hi stevos,
    I would look into the Aliminium cased screens.
    I think Sapphire do an aliminium cased screen range called the Parlkane Series. Slightly lighter than the Metal cased versions but the Parklane screens have a special braking retraction system which should prolong the lifespan of the screen.
    When looking at the screens, check the size of the casing. Manual screens are probably the lightest.
    Hope this helps
    Nik
  4. stevos
    stevos
    May 16, 2004
    6,179
    +580
    cheers
