tullochdave
First of all, hello this is my first post. Please be gentle
After a fair amount of research and several changes of heart over the last couple of months I have finally decided on the equipment that will make up my first home cinema, as follows.
Onkyo TX NR609 Amp
Tannoy HTS101 Speaker Package
Epson EH TW3200 Projector
My issue is with the screen, I am not sure which manufacturers are the better ones and which to avoid, I am after a manual pulldown screen (it is to be mounted on top of bookcases and will pull down in front of them), and my budget is about £400 max. I have read that curling and rippling can be an issue with these types of screens unfortunately I can not afford a tab tensioned one and a fixed one is not really practical for my needs as it has to be able able to disappear when not in use.
I have seen a couple of options -
Panoview Manual Pull Down - 234cm x 132cm (16:9) DS-9106PMG+
Panoview Manual Projector Screens
Leader Manual Projection Screen - 234 x 131.6cm
Leader Home Cinema Manual Projection Screens
Beamax R-Black Screen (10230) 244x141cm
Beamax R-Black Screen (10230) 244x141cm 16:9
Any advice on these screens or any others that might be suitable would be greatly appreciated.
Dave
Onkyo TX NR609 Amp
Dave
