Screen Adjustment on Grundig Television
Discussion in 'General TV Discussions Forum' started by sags, Jul 15, 2002.
  1. sags
    sags
    Have run out of "warranty time"
    Is there a way that the screen geometry can be adjusted on a Grundig 28"Model 702701FA Widescreen Television?
  2. bh
    bh
    Jul 14, 2000
    397
    Lost (no GPS here)!
    Not through the normal user menus. The service menus will allow this but this is definately not for the faint hearted. Might be worth getting a quote from an authorised repair centre.
    BH
  3. sags
    sags
    Thanks for advice...However the service part of menu needs a number !code to be able to use it !
    Any numbers known or getarounds ??
  4. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    apparently there's a "retailer only" option buried in the Grundig menus... if you try and select it it will ask for a passcode... for many Grundig's it is 8500 Try it out... but write down any settings before you change them. Also as I don't own a Grundig I really have no idea what the service menu is like inside!
  5. sags
    sags
    Many thanks RTC .. will try number.
  6. sags
    sags
    Sorry
    rct !!!!!
  7. sags
    sags
    rct
    Have tried the magic number !.. YES ! it worked, and I now have a reasonably well balanced screen ??
    Many thanks for the info.
  8. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    any time sags!
