screen above a radiator
Discussion in 'Projectors, Screens & Video Processors' started by dewalty, Aug 1, 2005.
  1. dewalty
    dewalty
    Jan 25, 2005
    19
    Hi, after for some advice. Looking to get a 92" screen, manual.
    Problem being, the screen with hang above a window, which has a radiator below it.
    Two questions,
    Will the heat from the radiator over time have any lasting effect on the fabric?
    Does anyone have a similar setup, and did you find that the screen moved with the convection effect of the radiator?
    I wonder if a tensioned screen would be better with regard to the movement.
    Many thanks in advance.
    Jay
  2. Oxfordguy
    Oxfordguy
    I've got a Draper Luma screen over my radiator and also in front of a very large window. It has got quite a lot of warping at the sides, heading to the middle.
    I don't know if this is down to heat though as I've read similiar complaints about the Luma from other members.
  3. adieboy
    adieboy
    Jun 1, 2004
    353
    +13
    I've got a Draper Luma- not over a radiator - warping and creasing all over the place, I'd hate to think what it would be like if i got it hot! It probably depends on the particular fabric used (avoid Draper, they're c**p).
    It's not just a matter of the screen moving in the convection current, another consideration is heat haze/shimmering, while viewing- I would imagine this could cause quite a bit of image distortion!
    Adie
  4. dewalty
    dewalty
    Jan 25, 2005
    19
    Thanks for the replies guys. Hadnt even thought about the possible heat haze problem, guess im going to have to suck it and see.
    Im going have to mount it a short distance away from the wall, to allow the screen to come down over the curtains, and so it wont be directly above the radiator maybe a few inches infront of it and above
    Just got to decide on a screen now..
  5. adieboy
    adieboy
    Jun 1, 2004
    353
    +13
    Nota Draper Luma, I hope.You've been warned!!!
    Adie
