Scratches on the screen, Thousands of them!!
Discussion in 'Plasma TVs Forum' started by GalacticaActual, Nov 13, 2004.
  1. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    So I am standing by the side of my Vierra. Imputting some thing up on the shelf . The sun is shining through the window and on to the plasma screen . I can notice lots and lots and lots of tiny surface scratches. Now The plasma has to be dusted every so often.Bcause the front of the plasma is plastice it also seeems to atract a hell of a lot of dust. I have followed the instuctions in the owners manual and used a lint free no abrasive cloth with no cleaning fluides of any kind. This does not really remove any of the dust and has seemed to have caused these scratches.
    Now , Granted, you can only see the scratches in full direct sun light and when you are standing right next to and to the side of the screen , but if the panal plastic scratches so easily, why make it out of platic to begin with?
    Can the plastic on the vierra be replaced? And if cleaning the front to get the dust off causes this sort of problem, then what is the answer?
    Anyone who can shed a bit of light on this would have my grattitude. I know it sounds a bit fussy as you can not see them from normal viewing distances and in my normal viewing light , but there must be a right and a wrong way to go about the cleaning of the screen and a way to protect it from scratching :mad:
  2. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,619
    London
    +468
    Said it before say it again.....
    Microfibre cloth and AF screen clene. Professionals choice.
    Lots of poeple use tissues(far too abrasive) leave swirls and fine scratches, such as you have experienced. Some use damp cloth, but then you have to dry screen in order to remove water marks and usually scratch the screen with your drying cloth.
  3. 1_crazy_mofo
    1_crazy_mofo
    Where can micro fibrecloth be purchased
  4. brackenlamb
    brackenlamb
    Oct 14, 2003
    421
    tesco asdao woolworths etc
  5. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    Have been useing a micro fibre cloth. but with out making it ever so slightly damp all you do is move the dust around the screen.
    Ekko, where do i get the screen cleaner from and is it 100% safe to use on the plastic screen of the Viera?
  6. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,619
    London
    +468
    or presoaked lint free AF screen clene wipes in sachets ;)
  7. neonmod
    neonmod
    PC world sell excellent panel wipes!
    Cheers! :smashin:
  8. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    And there is absoulute no danger of removing the anti glare coating off of the screen with these wipes? So to ask but need to be 100%sure :D
    Does anyone know if the front screen on the panal can be replaced?
  9. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    The af screen clene ones?
  10. jhkanguk
    jhkanguk
    If it's only dust, using air blower for cameras which costs only a few quid might be the perfect answer as there will be no physical contact. You just blow the dust away with wind!
