Scratched discs
Discussion in 'Xbox Forums' started by MELONzZ iG0D, Feb 7, 2009.
  1. MELONzZ iG0D
    MELONzZ iG0D
    Feb 7, 2009
    16
    Whats the best way to fix a scratched disc??? :(
  2. J4CK DANIELS
    J4CK DANIELS
    Aug 3, 2006
    1,483
    +231
    Take it to Blockbuster and they'll clean it for you! you can buy stuff that takes a very fine layer of the plastic off. you could also try T-Cut if you're feeling risky!!... i heard that putting them in the freezer did something too...
  3. MELONzZ iG0D
    MELONzZ iG0D
    Feb 7, 2009
    16
    Thanks alot but do you think there is way with household items. I tried this method with toothpaste but it didnt work, i also but it in a sonic cleaner but made no difference.:(
  4. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +56°28' 10.92"/-2°59' 21.48"
    +4,289
    take them to gamestation, £1.99 and they skim it and clean/polish it, in their machine.
    nothing you have in the house will do any good, other than to scratch it, or make things worse.
  5. dkopunec
    dkopunec
    Jan 19, 2009
    3
    I had the same problem with my COD- WAW. Clean it the best you can and then Install to your hard drive. might take a few attempts. If not you have to borrow or rent the came and install, then just use your original disk.
  6. Mr Noble
    Mr Noble
    Sep 28, 2008
    17,192
    Gateshead , Tyne & Wear
    +4,021
    house-hold items is a big no-no lol my mate took a brillo-pad to his cod:4 disc , needless to say it never worked again :rotfl:
  7. benmango
    benmango
    May 17, 2007
    1,343
    Liverpool
    +137
    Take it to Gamestation. I took my horrendously scratched FIFA 09 disc in there (refused to load/install to HD) and when I got it home it worked a charm. I was pleasantly surprised - was already sourcing a replacement elsewhere! :thumbsup:
  8. markgodley
    markgodley
    May 25, 2008
    6,864
    +2,469
    Gamestation. I took mine there, first time it still didnt work took it back to them and they did it 3 more times for me free of charge. Worked perfectly :)
    This is why you install games to your harddrive straight away :)
  9. Teddy Windsor
    Teddy Windsor
    Nov 22, 2007
    1,031
    +176
    Brasso (applied sparingly and gently with a lint-free cloth, then polished off and washed with boiling water) has resurrected both GOW and FM2 for me.
  10. Codehead
    Codehead
    Jan 20, 2007
    5,928
    Hanging around the goal in Rocket League
    +1,158
    I fixed a badly scratched Tekken 4 disc by polishing it with toothpaste on a soft wool sock. It takes a while but it worked a treat and the disk was minty fresh afterwards. :smashin:
  11. virtual22
    virtual22
    Dec 8, 2005
    3,901
    Looking at Falmer in awe!
    +762
    As per above I've had success with toothpaste and Brasso before. I've also used brasso to clean scratches off a mobile phone and IPOD. You need to use the right amount though or it can all go horribly wrong. Toothpaste will take a bit longer.
  12. AdsterUK
    AdsterUK
    Nov 4, 2003
    1,005
    Sunderland
    +81
    I've used the toothpaste method on audio cd's without problem. They went a bit cloudy but play fine :)
  13. Spooksta
    Spooksta
    Nov 7, 2000
    3,520
    Planet Earth
    +865
    T-Cut with a minty clean yellow duster. Then a bit of Mr Sheen for that mirror finish. :thumbsup:
    You have to work at the deeper scratches a few times. Usually takes me 10 mins to do a really bad one.
    Im a painter/polisher btw
    Works for me.
    :thumbsup:
  14. smallclanger
    smallclanger
    May 9, 2007
    2,246
    Southampton
    +463
    So was your sock too I would guess :D
  15. SteveU30
    SteveU30
    Oct 2, 2008
    5,537
    +1,985
    Glass cleaner and a very soft cloth also works well.
  16. Switch625
    Switch625
    Jan 15, 2005
    1,493
    +183
    I had a game that wouldn't load - tried all the household stuff myself (toothpaste, t-cut, turtlewax) but still didn't work. Took it to Game as I don't have a Gamestation near me and got it fixed for £2.93, works a treat now.
  17. Shardlake
    Shardlake
    Aug 27, 2010
    93
    Coventry
    Same for me too, brasso is the best imho
    Just use a SMALL amount and a blob of cotton wool, really does work :smashin: Had two games not reading, both are near perfect now.
  18. lead
    lead
    Aug 19, 2003
    653
    +62
    I bought one of these from Amazon a couple of weeks ago to sort a scratched game disk. It took 4 passes, but now works.
