W
Worthywow
I've just bought a second hand Toshiba 32ZD26 - cracking picture and, so far, none of the common faults that have been discussed on the forums
Only problem is that there is a slight scratch on the screen Since I've just bought it I keep spotting it but I guess I'll get used to it.
This may be a numpty question but is the glass on the front integral to the tube (or the tube itself) or is it separate and replacable ?
