scrambled sound
Discussion in 'Satellite TV, Sky TV & FreeSat' started by captainfearless, Oct 1, 2003.
  1. captainfearless
    captainfearless
    Mar 20, 2003
    73
    11
    when i listen to cable/sat sound through my sony 5.1 speakers
    in surround modes ,listening close to the speakers the sound is scrambled,although seated away it sounds ok.
    i have posted this problem b4 but can't resolve it ,so i wanted to know is this just how it is,when you morph pro logic into surround.
    can you guys put your ears to a speaker and tell me if it's the same for you ,with ntl or sky,astra ,whatever.
    if it's the norm i can live with it!
    thanks a million
    cf
  2. andymc
    andymc
    Sep 18, 2003
    266
    Bedford
    +15
    I just had this problem on Saturday when I reqired the system and changed some cabling - I found that it was caused by a Scart that had not been pushed home fully but was causing all kinds of havoc throught the system with the sound.... Check all is pushed home firmly is all I can suggest
