Scorpion King
Discussion in 'Movie Forum' started by Tight Git, Nov 9, 2004.
  1. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    I'm a great fan of The Scorpion King. :thumbsup:
    Yes, I know it'll never make the "Top Ten All-Time Classics" list, but it's good clean fun and Mrs TG adores The Rock! :laugh:
    The DVD of the film contains the usual extras (out-takes, deleted scenes, etc).
    Although more expensive, the triple DVD of The Mummy, The Mummy Returns and The Scorpion King is better value. :clap:
    Does anyone know if this includes the above extras, or is it just the film?
    Many thanks for any assistance. :)
  2. mad max 3
    mad max 3
    The Mummy is the SINGLE DISC RE-ISSUE with added DTS sound that wasn't there before. Its the same as the first disc from the old 2 disc set but with dts.
    The Mummy Returns is the first disc from the Mummy 2 disc set with dts.
    The Scorpion King is the same disc that was first relaesed with all the extras on it + dts.
  3. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    MM3,
    Many thanks,
    TG. :thumbsup:
