SCHT900 help please!
Discussion in 'Home Cinema Buying & Building' started by TankTopLover, Sep 19, 2005.
  1. TankTopLover
    TankTopLover
    Aug 28, 2005
    4,120
    +187
    I hvae the Panasonic SCHT900.I recently got a tv that supports progressive scan through component cable.So i set it all up and chucked a pal dvd in and turned on progressive scan on both the tv and the dvd player...it looks no different at all :(
    It says 'progressive' on the dvd player display so i know its selected?
    My player isnt multi region so is this a region issue? It seems silly that a pal player cant display progressive on a pal dvd :rolleyes:
    Can someone please let me know what i am doing wrong?
  2. TankTopLover
    TankTopLover
    Aug 28, 2005
    4,120
    +187
    UPDATE:
    Well after examining the manual i found that pal progressive is not supported!
    This seems stupid as its a pal player?
    So im selling it. ;)
    I need a pal progressive dvd player around £100-150 that is multiregion...any advice or recommendations?
  3. DarrenB
    DarrenB
    The Pioneer DV575 seems to be well regarded, PAL progressive scan, 99 quid, multi region.....from Richer Sounds.
  4. TankTopLover
    TankTopLover
    Aug 28, 2005
    4,120
    +187
    I have read that it has flicker when using pal progressive?
