scht-900
Discussion in 'Home Cinema Buying & Building' started by bruny, Nov 28, 2003.
  1. bruny
    bruny
    Nov 27, 2003
    290
    Scotland
    +17
    hi folks newbie here
    been looking at all in one systems and like the look and sound of panny scht- 900 but does it play copy dvd's any help would be appreciated
    cheers bruny
  2. rozzar
    rozzar
    Sep 29, 2002
    1,046
    41
    Braintree
    +23
    it'll play dvd-rs and dvd ram copied discs
    it'll also play cdr/cdrws
  3. bruny
    bruny
    Nov 27, 2003
    290
    Scotland
    +17
    cheers rozzar
    thanks for your help.thats what i wanted to know
    bruny
  4. naaz
    naaz
    Aug 15, 2004
    32
    Is it a multi region dvd player or can it be done multi region with the remote
    Naaz
  5. naaz
    naaz
    Aug 15, 2004
    32
    aaaaaaaaaaaaaaaaaaaaaa
  6. jayok
    jayok
    Sep 6, 2004
    57
    You can get it mutiregioned for about £20 with a remote.
