Schindler's List : Which version ?
thestorm
Established Member
Joined
Jul 13, 2000
Messages
551
Reaction score
Points
203
Location
East London, UK
Hi all
At present dvd compare recommend the R1 of this title
http://dvdcompare.net/comparisons/film_results_page.php?fid=4557
Im confused at to which version to go for :
Play.com advertise the region 2 :
Schindler's List - Special Edition Box Set
http://www.play.com/play247.asp?page=title&r=R2&title=156456&p=57&c=&g=72
and,
Playusa.com advertise the region 1 :
Schindler's List (Collector's Gift Set)
http://www.playusa.com/playusa.asp?page=title&r=R1&title=149342
Which is the best version to go for?
and
Where would be the best place to buy the region 1 version to
avoid import duties and taxes.
Thanks for your advice.
Cya,
Shaz
Well if you get the Region 1 Giftset from PlayUSA you will no doubt be hit with Customs Charges but then again the only other place I know of which wont give you custom charges is Movietyme and they want £49.99 for the set.
dvdboxoffice.com want ~£37 for the R1 gift set, and you won't get hit by customs with them.
Oh... they also have the 2-disc Master and Commander for ~£18... playusa.com want £24.99!!
dvdbox office sounds like a good option, but isnt their r1 dvds
covered in french writing and different from USA R1 dvds?
cheers for the hint! ;)
It's hit and miss with the french covers... some have them and some don't.
Bit annoying but I can live with it... if they had any sense, they would put english on side and french on the reverse. Though I don't think Schindler's List will be dual language thankfully (box sets generally aren't)! :smashin:
Hi all
Over the past couple of days Ive had a look at the dvd
specification of this title and it seems on the subtitles sections
they all differ!
Last year I made the mistake of buying the region 1 of
band of brothers and found that it didnt have any
english subtitles. I had to ebay it and get the Korean Military
edition. I dont want to make the same mistake with this title,
playusa.com states it does have english subtitles.and
dvdboxoffice.com & www.movietyme.com says it doesn't.
Which product description is accurate?
Pls check the following links:
http://dvdboxoffice.com/description...=MAIN&s=gg&rate=GBP++-2.4200++++&pid=90051583
http://www.movietyme.com/catalog/product_info.php?products_id=18894
This is getting so confusing! :(
Cheers,
Shaz
Play Customs Charges???
Right, I think I've sussed out whats going on... When I add Master & Commander to the basket on Play, no problems, when I add the 2 disc special edition to the basket I get a warning stating that I might get charges, so presumably this is the customs charges your refering to... Why is it that some discs attract this message and others don't?
Sorry if it's a simple question asked many times before...
Edited to say: meant PlayUSA
Barry
If its over £18 then i believe customs can charge extra if it's under they cannot, unless you fill in a form stating its a gift from someone or to someone then you are allowed upto £35.
RESTORATION vs. REVISIONISM: At what point do 4K video and audio 'upgrades' cross the line?
Back
