schematics
Discussion in 'TAG McLaren Audio Owners' Forum' started by johnson, Jun 12, 2005.
  1. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    Would any of the ex TMA employees have schematics for the 250*3/100*5 amps?
    Not for any reason other than I've quite an interest in amp design(only recently) and would love to have a look!
    Best regards
  2. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
  3. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    Thanks Steve
    Much appreciated
    Regards
  4. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    If you're interested in aspects of other amp design etc,you could also take a look at www.passdiy.com which is the DIY end of Nelson Pass's amplifier and speaker design collection...everything from the old Zen amps to the Aleph's are in there,plus some fascinating home built designs based on his schematics.
  5. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    Hi Alex.
    Thanks, I'll check it out.
    I've already downloaded the bryston schematics (thanks Steve).Very interesting.
    One comment, the TMA designs seem to "get away" with relatively small caps when compared to some of their competition.
    Regards
  6. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    If the amplifier design has good ripple rejection capability then you don't need huge smoothing capacitors. This also has the benefit of smaller amplifiers, reduced cost and normally higher performance in the real world as fluctuations on the supply side don't make it through to the output.
  7. The_Speculum
    The_Speculum
    Apr 2, 2005
    276
  8. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    Yeah thanks,The TNT one was the first one I read.
    Steve, thanks for the explanation
    Regards
  9. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    A friend of mine recently had his Quad amp serviced by IAG.
    They told him they had measured the caps and they had degraded over time and needed replacing . Which they did .
    I don't doubt they had degraded or that they needed replacing, but I was wondering , what equipment would you use to mesure the degradation of the caps?
    Is it something anyone with a reasonable knowledge could do?
    Regards
  10. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    Use a LCR meter. You can use some multimeters that have a capacitor mode, but they're typically not that accurate on large electrolytics.
    You normally find that by the time you've stripped the equipment down and removed them sufficiently out of circuit to measure, you may as well as changed them expecially if they're getting on a bit.
  11. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    :rotfl: :rotfl: :rotfl: :rotfl: Oh if I had a pound for everytime I've done that......
  12. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    A clue maybe to why they all sound the same ;)
