Iccz
Basically i'm trying to use Robocopy on a W2K server to copy files from a mapped network drive (Z:\) to a drive on the local machine (X:\).
I've made a batch file with the following:
Obviously the actual folder names differ.
Either way, this command works perfect via CMD, so I put the batch file up for a scheduled daily task, made a text file in Z:\Folder and ran the scheduled task, nothing. Nothing except the error code 0x10.
After the scheduled task failed I ran the batch file again, and the text file was copied over, I deleted it then tried the task again, nothing.
Googling around a little shows some people with a similar problem when using Robocopy, but I can't find a solution to it anywhere.
Anyone got any suggestions as to what I can try to fix this scheduled task as i'm a bit baffled now...
Robocopy Z:\Folder X:\Folder
