Scart working 2 way simultaneously?
Discussion in 'Cables & Switches' started by SyG, Apr 24, 2005.
  1. SyG
    SyG
    Apr 24, 2005
    138
    On TVs that have an outgoing and ingoing scart, I’m wondering if using an adaptor, you can have a piece of equipment going in whilst sending the TV signal out? Are the pins separate for ingoing and outgoing signals? If the signal going in is the same going out, does it matter anyway (eg dvd player in, then signal out of TV to go into hifi)?
