PH001
Sorry if this has been covered before, I did a search but I still couldn't quite find the answer to my question.
I have a Panny AX100E and am trying to figure what cables to run (10m) over my celing to my sources. My sources aren't very flash at the moment, they are:
PC with DVI out Gfx card
Toshiba SD230E DVD player with Scart, S-Video & Component out
Sky digibox with only SCART out
I'm not entirely sure what is the best way to connect all this up.
I'm obviously going to run a 10m HDMI cable and am considering buying a 10m S-Video and a 10m Component cable as well. I have a slight dilemma with the Sky digibox though, what would you say is the best way of converting the SCART output from it? I have seen some SCART to S-Video converters for very little money, would that result in better quality than say a SCART to composite converter?
I also have a rather more general question that maybe you could help me with. I understand that all the signals that I mentioned in the title are analogue, but which of these offer component video signals and which of them are composite video signals. If SCART is component (i.e RGB) and S-video is likewise, why is S-video regarded as superior and why are SCART to component converters so expensive if it is already in component format?
Also, I've seen many SCART to composite converters for very little money, so I guess it is very easy and cheap to convert a component RGB SCART into a single composite video signal? I thought that would be quite involved. Or do I just not understand any of this properly at all !!!
