Scart upgrade advice
Discussion in 'Cables & Switches' started by Stiffler05, Sep 4, 2005.
  1. Stiffler05
    Stiffler05
    Hi guys,
    I've recently had sky installed and have been using it on my new 32" samsung lcd tv. When the sky is set to rgb mode the picture quality isn't that great (visible vertical lines and text is pretty jaggy). So i'm looking to buy a decent quality scart cable to see if the rgb signal can be improved. Pal is fine btw.
    A couple i've looked at are:
    http://www.tvcables.co.uk/cgi-bin/tvcables/FORUM-SP1.html
    and
    http://www.tvcables.co.uk/cgi-bin/tvcables/PGV7000.html
    These two look pretty good, but are fairly expensive. Is it worth spending this amount on a new cable which may not fix the problem or should i just go with a £5.99 one which will do the job?
    Any advice would be appreciated.
