scart to VGA??
Discussion in 'Cables & Switches' started by lhough20, Aug 12, 2004.
  1. lhough20
    lhough20
    just out of interest....
    as i'm relatively new to the av world, what would be the resulting picture quality if i connected my sky+ box to my sony kf42sx300u (42" rear projection lcd) with a "scart to VGA" lead...see below:
    http://www.keene.co.uk/cgi-bin/codesearch.pl?SGB12
    would it be any better or worse than my current RGB "monster" scart lead?
    Also does anyone know where i can get the avia setup disk?
    Lee
  2. NSP
    NSP
    Dec 30, 2004
    50
    Harrogate
    Did you try the "scart to VGA" as I had the same idea.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,437
    Rainham Essex
    +2,470
    The scart to VGA lead should give a good picture, but it wont be better than a direct scart to scart lead. You can't get extra PQ with conversion, but if done badly you will loose PQ. The only way it will be better is if the scart input is poor on the screen.
    In the past I had a scart to VGA converter from www.js-technology.com which is a more expensive converter but is the best available. The PQ was excellent but I can't compare it to a scart to scart connection as I don't have a scart input on my plasma.
    In the past I have seen many posts on this forum from people that have had problems with the syncblaster cable and others that have been very pleased with it.
    Mark.
  4. NSP
    NSP
    Dec 30, 2004
    50
    Harrogate
    Thanks Mark,
    I won't bother and will stick with RGB scart.
