Scart to VGA Cables in UK
Discussion in 'Cables & Switches' started by slaguru, Jan 22, 2004.
  1. slaguru
    slaguru
    Hi Guys
    I have a KiSS 508 connecting to a Sony PMF42 E2. I would like to connect direc t to one of the RGB/YUV VGA 15pin ports direct from the player, so I need a Scart to VGA cable.
    Does anyone know where I could get one in the UK. I have looked everywhere. I might be missing a trick here, but I cant find a seller anywhere.
    Cheers Guys
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,283
    The Borders
    +2,573
    slaguru
    Not really a 'standard' cable that one - though we have a couple of manufacturers who will make one up to order.
    If I understand it correctly you are looking for:
    1 x SCART (YUV) to HD15 (YUV) - I take it you have confirmed your display does accept YUV on its HD15 input?
    How long a cable do you require - keep in mind the labour to built it will be more costly than an extra meter or so of cable so dont skimp on cable length.
    Best regards
    Joe
  3. slaguru
    slaguru
    Yep its a scart YUV to HD15(YUV). The Sony can take an RGB or a YUV(componant) input on its HD15 input.
    I guess I would need a 3m cable.
    Tim
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,283
    The Borders
    +2,573
    Hello Tim
    You have a PM.
    Best regards
    Joe
