Scart to VGA Cable - Connecting a PS2 to a TFT monitor
Discussion in 'Cables & Switches' started by Jamie Bug, May 2, 2007.
  1. Jamie Bug
    Jamie Bug
    Mar 27, 2007
    101
    Devonshire
    My new video setup currently compromises of a 22inch TFT Monitor connected to my Xbox 360 via the official VGA cable. Obviously, as TFT monitors aren't TV's, there's no other inputs on there and more to the point no Scart input via which I can connect the PS2.
    Therefore, I'm in the market for a cable or adapter which converts the scart signal from the PS2 to VGA so I can attatch it to a VGA switch, which is then attatched to my monitor allowing me to switch between 360 and PS2.
    First of all, is this possible as my monitor ouputs in 16:10, not 16:9?
    Secondly, At the moment, the only cable I can find that hasn't been discontinued by the seller is this one. It looks like it'd fit the bill, but at £30 it's a bit rich for a length of wire. Can anyone recommend me a cable or adapter that works well and is no more than £20? There are quite a few on ebay, but they all look homemade and are scarily short, whereas I need at least a metre of lead.
    And thirdly, I mentioned that I'm going to be connecting this cable to a VGA switch box so I can switch between 360 and PS2 -- will I lose picture quality, and if so, how much? I'm more concerned about the 360 picture than anything, and if it's anything largely noticeable I won't bother at all.
    Cheers to those who reply :)
  2. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,931
    2
    The Fylde Coast
    +13,698
    This is the same cable:
    http://www.amazon.co.uk/MVS-Scart-VGA-use-projectors/dp/B000LD8JFO
    Note:
    # Scart to VGA cable.
    # This cable allows you to easily connect RGB scart equipment directly to Plasma, LCD Screens and projectors.
    # Please note this cable does NOT convert scart RGB into an SVGA computer signal.
    You need a converter to get from RGBhv to VGA for a computer monitor.
    The best you can get apparently is this one., but at over £100 it ain't your £30 cable either!
  3. Jamie Bug
    Jamie Bug
    Mar 27, 2007
    101
    Devonshire
    Tsch, well if I ever feel I need to, I'll just get the £30 cable. Why are those switches so expensive?
  4. Jamie Bug
    Jamie Bug
    Mar 27, 2007
    101
    Devonshire
    Any other thoughts guys? I'd appreciate them a lot :).
  5. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,931
    2
    The Fylde Coast
    +13,698
    Er, no you won't unless you want to waste £30.
    A cable like that will not work in your set up. Period. You need a converter, and that's why they are expensive!
  6. Jamie Bug
    Jamie Bug
    Mar 27, 2007
    101
    Devonshire
    Oh I see. Won't bother then. Cheers for the heads up.
