Scart to TV aerial! desperate for some help with this ...
Discussion in 'Cables & Switches' started by Dystran, Dec 18, 2004.
  1. Dystran
    Dystran
    Jan 25, 2004
    172
    16
    I have a source (Homchoice TV box) that only has a scart out connection.
    I have one of those 7.5 inch portable TV's that only has:
    (1) an "ANT in" earphone type small socket (i have a wire changing this to aerial), and
    (2) a USB socket that says "A/V" (not sure if its an IN or OUT socket.
    I think I need something that will convert the SCART signal to my aerial in socket.
    Is there a cheap "cable" type way of doing this? or do I need to spend more on a whole converter box type system.
    Really looking for a cheap budget way of doing this, if it can be done at all ... hmm
    Wuld really appreciate some help - thanks in advance if you can ... (maybe this will be an excuse for me to go buy a big ol' plasma TV heh)
  2. Flimber
    Flimber
    Sep 22, 2002
    13,679
    Yorkshire
    +4,476
    You need a 'modulator' device, or a cheap VCR with an AV input ;)
    Mike.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    a USB socket (thats a serial data port) labelled A/V an analogue video label.... link to TV manufacturer? and why use a 7.5" TV?
  4. Dystran
    Dystran
    Jan 25, 2004
    172
    16
    I know, the USB port confused me - not sure how it can be used lol.
    Its a 7" LCL monitor/tv. Its small and portable. I have it on while working at my pc, sits niceley next to my PC monitor (multitasking!). Also move it to the bathroom, or kitchen if I want to watch some TV there, quite useful actually.
    http://homepage.ntlworld.com/allcam/manuals/318GL-70TV.pdf
    Any cheapo modulator devices out there :)
  5. Dystran
    Dystran
    Jan 25, 2004
    172
    16
    ahhhh that file shows a picture of an A/V cable - USB one side, and phonos on the other - i wonder if they are "in" or out" capable - i didnt get this cable with the set though pah.
  6. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    The manual you posted shows an AV adaptor cable, with two video inputs a sound input and a 12V supply input
    The fact that it looks like a USB connector doesn't make it a USB cable.
    Maplin Electronics do an RF modulator which accepts a scart input for £29.99 - Maplin item No. VH89W
