Scart to Six phono
Discussion in 'Cables & Switches' started by keefy_boy_uk, Apr 12, 2005.
  1. keefy_boy_uk
    keefy_boy_uk
    Help.
    I have just brought a Hitachi 42PD5200 and a Denon D-m51dvs. I want to use a scart on the Denon and a six phono connection on the Hitachi. My dilemna is that as a bit of a thicky, the six phonos are made up of 2 Yellow 2 red and 2 Black. But the connectors the diagram in the Hitachi booklet shows me are red, green, blue red yellow and white. They dont show which one of the leads go where? Very confused and bewildered.
    Can anyone help a newbie who just wants to get as best a picture as he can. I have brought good quality cables.
    Thanks anyone who can help...... :lease:
  2. Damnyoureyes
    Damnyoureyes
    Jun 17, 2004
    46
    Not wholey sure if this is going to help much but going by the colours and the amount of connections
    I think the 6 phono scart with 2 yell 2 red and 2 black will most probably be just composite video and stereo sound in and out (yellow video, red black left and right sound)
    on the other one one will be the composite and stereo sound (yell and red and white) and the other bit component (red, green and blue).
    What's the actual SCART lead say it's meant to be for? I don't think you'd get the component outputs out from the SCART?
    Looking at the specs for the Hitachi I think you just need a fully wired SCART from AV4 to the Denon?
    What have you tried so far?
    I've added some links to the individual bits maybe somebody can be of further help
    http://www.hitachidigitalmedia.com/DMG/viewProduct_1.jsp?productid=340&drilldown=2&urlnumber=0
    http://www.denon.co.uk/site/popup/ansicht.php?p=ansicht&Pid=158&bild_nr=6
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,131
    Rainham Essex
    +2,393
    I also think the scart to 6 phono lead is for stereo audio & composite video for signal in & out of scart. It wil not AFAIK carry YUV component or RGBs.
    What I think you need is a scart to 'VGA 15 pin D-sub' lead, but this will only carry the video and not the audio. You will therefore need a separate phono stereo lead for the audio if you want sound from the screens own speakers.
    Mark.
