Scart to S-video
Discussion in 'Projectors, Screens & Video Processors' started by Comer, May 2, 2003.
  1. Comer
    Comer
    Sep 21, 2001
    1,384
    Ireland
    +85
    I'm thinking about getting a scart to svideo convertor to send sky from my digibox to my projector. What would people recomend for this and would I see much imporvement over using a composite lead
    Edit: The convertor does not need to be RGB scart to svideo
    Conor
  2. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    The John Sims one is generally regarded as the best although I haven't tried it, I used to have the Keene one and that worked fine although I also tried the Lektopaks one which gave a large picture shift to the side.
    and yes it really is a noticable difference.
    Sky+ is what yoiu really need!:devil:
  3. Comer
    Comer
    Sep 21, 2001
    1,384
    Ireland
    +85
    Oh how cruel you are, :D it's not yet available in Ireland
  4. Comer
    Comer
    Sep 21, 2001
    1,384
    Ireland
    +85
    Can this be bought online?
    Conor
  5. Mr Cheese
    Mr Cheese
    Dec 12, 2002
    412
    Down South
    +19
    Comer, I have the John Sim converter and it is fantastic.
    The improvement over composite is VAST. Rock steady and no PAL gribbling at all. What's more, on the version 2 there is RGB passthrough for the tv so there's no messy switching between tv and projector. It's there for both all the time. Also WSS is maintained.
    I can't praise it highly enough. I got mine cheap off the forums - there's no harm in asking first. The company address is
    www.rgbtosvideo.com
  6. Kramer
    Kramer
    As your a HCPC man (DVI :clap: ), run Dscaler.
    Switching between DVI & any other source will necessitate rezooming (to account for the "overscan" border).
    S-video > capture card > dscaler > DVI > HS10 = :eek:
  7. Comer
    Comer
    Sep 21, 2001
    1,384
    Ireland
    +85
    Hi Kramer
    No matter what setting I use I get very bad stutter using dscaler. What settings are u using in dscaler to give stutter-free playback.
    Also I need something that is a little more wife friendly
    Conor
  8. Pulsar
    Pulsar
    Jan 19, 2003
    3,137
    West Midlands - Stourbridge
    +332
    I have the same problem as Comer, I can only get stuttered playback from dscalar to my HS10. Whats the trick?
    Rob
  9. Kramer
    Kramer
    Hi guys.
    What CPUs/systems are you using?
    Are you sure it's not dropped frames? Adaptive noise & judder termination etc.. put the cpu under 100% load - need a good spec PC for that!
    Check if it's this that's happening :)
  10. Comer
    Comer
    Sep 21, 2001
    1,384
    Ireland
    +85
    Hi Kramer
    I'm running a P4 1.4. I must check the CPU usage next time I'm running dscaler
    When are u going to call and check out the closest (I think) HS10. It might be interesting to compare the brightness of mine to yours. I've got something around 120 hours with absolutely no problems
    Conor
  11. Comer
    Comer
    Sep 21, 2001
    1,384
    Ireland
    +85
    I checked the CPU usage over the w/end and yes it is at 100% when using Dscaler. Anything I can do about this?
    Conor
  12. Kramer
    Kramer
    Yep - start a new thread in HCPCs :D
    You seem to have rec'd excellent advice in your new thread. What the guys said - I concur :smoke:
