scart to s video
Discussion in 'Cables & Switches' started by ianlecompte, Dec 23, 2003.
  1. ianlecompte
    ianlecompte
    Sep 17, 2002
    951
    oxfordshire
    +13
    is it possible to get a long lead 5 to 10 metres one end scart the other an s.video to connect sky box to projector?or a convertor box.thanks for any advice
  2. DucatiEVO
    DucatiEVO
    I brought a small scart - SVHS adapter (a tenner), to plug into my Quintro+ switch box, then ran a 5m SVHS cable (which I already had) to my Xbox. I didn't get mine from here:
    Scart Adaptor
    But it's the same and that one is only a fiver! :eek:
    Works fine on my system and saved wasting a good 5m SVHS lead I already had.
    Otherwise you can buy the lead you're after but not sure if it's available in 10m, normally seems to come in around the 3/5m mark (QED etc).
  3. FlimsyFeet
    FlimsyFeet
    Oct 18, 2003
    91
  4. ianlecompte
    ianlecompte
    Sep 17, 2002
    951
    oxfordshire
    +13
    thanks guys,i will check it out today,need to see if i can get one locally,i want it for the holidays.
