Scart to S-Video/RCA Audio
Discussion in 'Cables & Switches' started by timiano, Feb 17, 2005.
  1. timiano
    timiano
    Feb 17, 2005
    65
    9
    Cheshire
    I've owned for some time a SkyFunk SL3 Video Sender (http://www.sateuropa.co.uk/product_overview.asp?id=394&catid=2&subcat=12). The output of these is via Scart (male) which is no problem for connecting to a standard telly.
    However, my requirements have changed. I'm now using the video sender to attach to a Winfast TV2000XP TV/Video Card which has a dongle with S-Video and L/R phono Audio. So, I need to get the scart from the video sender to S-Video and 2 channel audio.
    I've had a look around, and I've seen a few things on maplin. Will this work? :-
    http://www.maplin.co.uk/Module.aspx?ModuleNo=33041&TabID=1&source=14&doy=17m2
    or, use both of these two
    http://www.maplin.co.uk/Module.aspx?ModuleNo=28096&TabID=1&source=17&WorldID=&doy=17m2
    http://www.maplin.co.uk/Module.aspx?ModuleNo=13398&TabID=1&source=14&doy=17m2
    Thanks in advance people
    Tim
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,600
    Rainham Essex
    +2,543
    Both the sets of links you show will work - but only if the video sender can carry an S-Video signal, and as long as it is fed with S-Video!
    If the sender does not work with S-Video then you will get a Black & White picture.
    Mark.
