SCART to S-Video on Panny 6
Discussion in 'Plasma TVs Forum' started by daveb975, Dec 22, 2003.
  1. daveb975
    daveb975
    Oct 25, 2002
    4,248
    103
    London
    +347
    Is it possible to use a SCART to S-Video cable to feed a Freeview signal into a Panny 6 plasma?
    I have a free S-Video connection, and this would save me buying a £130 SCART board.
  2. DucatiEVO
    DucatiEVO
    Don't see why not, I do it the other way around for my Xbox and go S-video into Scart (the Panny6) with no problems.
    What board are you using, if it's the dual one that shares an S-Video with a Composite connection then you can only use one at a time.
  3. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,516
    Kent
    +830
    It is NOT possible since the freeview box isn't actually sending out an s-video signal type, it will be sending out composite video and RGB video. You can either run scart to composte video (very poor quality), buy a suitable converter to convert RGB to S-video (80 quid) or just buy the scart board!
  4. daveb975
    daveb975
    Oct 25, 2002
    4,248
    103
    London
    +347
    Thanks Liam.
    I think I will just buy the SCART board in that case.
    I am in the Tun Wells area over Christmas - do you keep them in stock?
  5. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    Doesn't this depend on the Freeview box being used? My Sony one has an option of S-video (Y/C) on the main SCART.
    Not sure of how the quality compares to RGB SCART though. (I use RGB SCART myself with my PW6).
    Mark
  6. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    Liam, surely you've come across freeview boxes that do s-video on scart? Loads do, netgem, sony, nokia, pace even does it on scart 2, and that's not unique. What's proposed may be perfectly feasible, but before buying anything, look in the video setup menu of the box and see what the options are. S-video signals are as pointed out, not quite up to RGB standard, but not half bad, quite watchable for most of us on a plasma. Not you Jasonjo of course, but most of us.
  7. daveb975
    daveb975
    Oct 25, 2002
    4,248
    103
    London
    +347
    I doubt my 'Freeview' box will have anything like that (it is one of the old ONDigital Philips ones!)
    It sounds as though it could be cheaper to upgrade to an S-Video compatible Freeview box, but if RGB will be better quality I guess I may as well get the SCART board for the plasma.
    Thanks for the opinions.
  8. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,664
    UK
    +115
    Cheeky Git! :p
