scart to s-video & 2 RCA NOT vice-versa. Argggh
Discussion in 'Cables & Switches' started by Jules, Jun 7, 2004.
  1. Jules
    Jules
    Oct 11, 2000
    5,534
    +1,005
    Just got the Pioneer freeview box and wanted to connect it to my Av Amp using S-video from the VCR scart socket.
    So, I went to maplins to buy a THOR "Scart to S-Video & 2 RCA"... which I did!
    However, its actually wired in the reverse direction.
    You'd think if the box is labeled "Scart to S-Video & 2 RCA" then it should wired in that direction. Bloody stupid.....
    It should be described as "S-Video & 2 RCS to Scart".
    The annoying thing is that neither THOR nor any of the other cable companies seem to sell what I need.
    Even more annoying, is that when I actually needed this cable a couple of years ago, they were all sold in the opposite direction (i.e. the direction I need now).
    Why don't the manufacturers understand their own products! And why make these cables in only one direction?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
  3. Jules
    Jules
    Oct 11, 2000
    5,534
    +1,005
    Yes, I used to use these, but unfortunately the adapter + cable sticks out too far at the back. There isn't room and it puts a strain on the socket.
    I've found that QED still make what I need, but at £50 they can keep it!
    I know IXOS used to make a green one for about £25.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,261
    Rainham Essex
    +2,404
    I don't know your Freeview box, but before you spend any more money I just thought it might be worth mentioning that the vast majority of UK STB's don't output S-Video - does yours?
    Also if it does I would be surprised if it did via the VCR scart as this is (nearly?) always composite only.
    Obviously I don't know what other equipment you have connected up, but why do you want to go via the AV amp? Going directly into the TV with an RGB scart would give a far better PQ than you would normally get from S-Video.
    As I say, I'm not trying to p:censored:s on your ideas. I'm just trying to prevent you possibly making some expensive mistakes.
    Mark.
  6. IanDH
    IanDH
  7. Jules
    Jules
    Oct 11, 2000
    5,534
    +1,005
    Mark, thanks for the advice but the Pioneer DOES output S-Video from the VCR scart.... it's one of the very few that does and one of the reasons I bought it.
    The TV scart is RGB going straight to the TV, but the S-Video output will be routed to my amp and from there distributed to everything else... including DVD-R, Projector etc, etc.
    I can't do an RGB loop through to the TV either, as my SKY+ box already does that.
  8. stevenwilliams
    stevenwilliams
    Mar 17, 2002
    36
    Crawley, West sussex
    I understand your frustration. I sell Thor cables on ebay and have specified the direction in the description. Still many people buy them thinking I am wrong and the box is right.
