Quantcast
scart to rgb adapter - where from
bigrabbie
where can i get a scart to rgb adapter (yuv)
maplin used to have them for £12
as usual, your guidence will be appreciated
M
Member 34135
Although advertised as RGB, that adapter will only work for RGB if you can sync on green, most consumer kit requires the separate sync (composite video pin of scart). It is good for component video, YUV.
Andy.
