Scart to RF Aerial?
Discussion in 'Cables & Switches' started by caleb2002, Jan 17, 2004.
  1. caleb2002
    caleb2002
    DOes anyone know where I can get a cable/connector to output from Scart or Svideoto RF?
    The tv I am trying to connect to is about 20 years old and the scart connection only seems to allow audio (the remote has a hifi button which turns on this connection).
  2. CARLOS
    CARLOS
    Feb 11, 2001
    6,437
    WEST MIDLANDS
    +1,411
    No such thing unfortunately, You need an RF modulator to convert RF to Scart.
    Modulators are available from places like Maplins and Keene electronics !!
  3. Brian110507
    Brian110507
    Go to www.keene.co.uk and browse to the 'products' page and then search for product code KRFT
    This goes inline with the aerial input on your TV and has phono sockets to connect an input from your scart connector
  4. caleb2002
    caleb2002
    Thanks for that link, was really trying to do it on a budget so was hoping their would be a £1.99 adaptor or something.
    at £30 for the Keene box, the in-laws could probably get a second hand tv with a scart (but they won't)
    cheers anyway.
