scart to DVI
Discussion in 'Plasma TVs Forum' started by googlybear, Nov 10, 2004.
  1. googlybear
    googlybear
    Nov 10, 2004
    169
    16
    Hello again all
    would it give me a better picture on my LG PX11 from sky if i got a cable that converted my scart output to a dvi input or will i need a scaler to do this?
    sorry about the naff question but i am a newbie at this
    Thank you
  2. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    SCART is an analogue signal, DVI-D is a digital signal, assuming that you are talking about the digital version or the digital side of the DVI-I input.
    To convert from SCART to DVI-D, you will need a converter of some kind. As you mention, a Scaler is one such device and may be beneficial in improving the picture quality. For example, my DVD player includes a scaler for external sources and outputs via HDMI/DVI. A freeview s-video source upscaled to 720p and deinterlaced is much better than the standard RGB SCART signal when viewed direct.
    If you were talking about the analogue side of a DVI-I input and your plasma supported VGA input via the DVI-I connector, you could try a RGB to VGA converter, such as the one from JS-Technology. But this would only give you a standard definition signal so you may not see so much of a difference.
    -Ian
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    An IscanHD may well do the trick..£1000 Pretty sure the JS box wont with LG as it needs display to accept 15HZ horizontal line sync... LG wont accept this...... A cheaper option might be a Briteveiw or similar lower end unit Iscan Pro etc £175 ish S/
    H
    http://www.avforums.com/forums/showthread.php?t=162199
  4. neonmod
    neonmod
    JS VGA converter will not work with the LG!
    What i have done is make my own scaler for sky+ that is far superior to any up-converters / scalers and only costy me £40 not £1000.
    Get your self a capture card (i bought a leadtek tv2000 expert for £40) connect sky+ s-video output to the capture card input and download d-scaler, free off the web.
    Bingo you have an excellent scaler for £40! :smashin:
    Pictures are brilliant / faultless with my PX11.
    Any questions, post here and i will help!
    Cheers!
  5. googlybear
    googlybear
    Nov 10, 2004
    169
    16
    thanks to you all
    I actually have sky as i am not blessed with sky+ yet!! so i only have a scart output. I assume the info given could still be used if i get a scart to rgb convertor aswell
    Thanks again
    BTW does this scaling lark get rid of solarization on faces on your px11 or have you never had that?
  6. neonmod
    neonmod
    You get solarisation on low quality input sources, so Yes to your question!
    You can get a Scart to S-video lead for Sky!
    Cheers! :smashin:
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    but that wont work.....as sky cant output S-video via either scart......... Just cause scart can carry S-video doesnt mean it does...
  8. googlybear
    googlybear
    Nov 10, 2004
    169
    16
    ok dilemma then. What do you suggest i do for a bog standard sky box? apart from upgrade to sky+ :)
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    buy a grundig off ebay these had S-video output sockets...OR JS Technology RGB>S-video converter or upgrade to Sky+........ Cancel sky and buy a FV box with component out........
  10. neonmod
    neonmod
    Okay thought you could get S-video!
    All is not lost, my way also works for composite video out, which can be obtained through the scart.(scart to phono composite and audio).
    PQ is reported as being excellent and is used by most of the capture card users out there anyway!
    Hope this helps.
    Cheers. :smashin:
