scart to component
Discussion in 'Cables & Switches' started by bigtank, Jul 4, 2004.
  1. bigtank
    bigtank
    May 21, 2002
    188
    belfast
    hi
    my toshiba 32zt29 tv has component in sockets,can i connect my sony vtx-d800 freeview box scart output to the toshibas component input.
    if so what cable do i need.
    p.s.
    i know my tv has a build in freeview receiver but it is crap compered to the sony :lease:
  2. SamirP
    SamirP
    Apr 28, 2003
    1,303
    South Of The River
    +38
    Hi Bigtank
    I don't think that d800 is able to output a component signal via the scart only rgb. If your dvd player has component outputs then just connect the dvd to your TV's component input and use the rgb scart for freeview
  3. bigtank
    bigtank
    May 21, 2002
    188
    belfast
    hi samir
    my dvd player does not have component outputs, but the sony outputs RGB,PAL orY/C
    ANYBODY HELP PLEASE
  4. SamirP
    SamirP
    Apr 28, 2003
    1,303
    South Of The River
    +38
    You buy a RGB to component converter from JS Tech
